LightBurn loader 1.0 (new) - New plugin to convert LightBurn
Re: LightBurn loader 1.0 (new) - New plugin to convert Light
Postby cseyler » Sun Nov 21, 2021 10:08 pm
I've attached a gc created with lightburn for a Marlin device.
By using this device, it is possible to export the laser power. The device (and the gcode) uses m106 S0 to turn off the laser and M106 Sxxx (from 0 to 255) to turn on the laser with a specific power.
I assumed that the plugin will convert this file by replacing m106 S0 by M11 and M106 Sxx by M10 Qxx.
But the plugin just remove the S paramter behind the M106
AM i missing something ?
testMarlin.txt
(17.04 KiB) Downloaded 475 times
cseyler
Postby dezsoe » Wed Nov 24, 2021 10:21 am
The LightBurn Loader is written for "GRBL-M3" style codes. Generate the g-code for this output with the S set to 0..255.
Postby cseyler » Wed Nov 24, 2021 2:25 pm
Ok thanks, I tried with GRBL instead of GRBL-M3 ... with M3, it works fine
cseyler
Postby andre99 » Tue Nov 30, 2021 10:24 pm
Hello, but use Uccnc where this plugin is also made for.
But only get is a blue screen wen i load the made gcode.
What I'm doing wrong hope some can help me
andre99
Postby Snidelwoodz » Wed Jan 05, 2022 9:13 am
I've tested your loader on a simple file but it set the laser power to 800 (80% in lightburn).
Using the scale option (0 to 255) doesn't change anything ...
See the image attached
Snidelwoodz
Postby andre99 » Sat Jan 29, 2022 6:32 pm
cseyler wrote:Hi,
Sorry i try to understand what you mean but i only get a blue screen in uccnc that what he goes to laser so only horizontal lines and no photo.
I hope you want to help me out, i try the do my best but i cannot find the problem what i do wrong.
andre99
Postby andre99 » Sat Jan 29, 2022 6:40 pm
Could someone help me I can't manage to convert a photo that I have loaded in lightburn into gcode
that I can load in Uccnc lightburn plugin.
All I keep getting is a blue screen and I can't see anything. What am I doing wrong now????
This is only what i get.
I have try what i can but only the blue horizontal lines.
I hope that anyone can help me with a step by step how to do it.
andre99
Postby Robertspark » Sat Jan 29, 2022 7:36 pm
thats because uccnc shows the PATH, not laser intensity
Postby andre99 » Sat Jan 29, 2022 7:46 pm
Normal you see the photo there and now only lines. Further wen i zoom in then there are only lines.
I test it and it gives only horizontal lines in full power.
andre99
Postby cseyler » Sun Jan 30, 2022 7:57 pm
You can only see the picture when you use the Laser Engraver plugin.
Lightbuirn generates a gcaode, slightly modified by the lightburn plugin. But it remains toolpath (blue line).
cseyler
