AXBB-E Problems with Mach3 turn
Postby Berti » Wed Oct 06, 2021 9:04 pm
Hallo from germany,
I have my second AXBB-E controller and after converting a mill to cnc using uccnc, i now want to do the same with a lathe but using mach3 turn.
I no have my servos running, homing also works but i have a few Problems:
My changes in the axbbe plugin manager do not save.
Every time i restart they are lost. All other settings stay.
And the second problem is, i want to have my spindle controlled via pwm and vfd.
cw works but ccw doesnt.
It switches the output on, but nothing happens.
Next Problem is the spindle only runs for a few seconds sometimes longer and sometimes less.
It shuts the outputs off without doing me anything...
I reset the controller but doesnt change anything.
I would be really thankfull if someone could help me.
Berti
Re: AXBB-E Problems with Mach3 turn
Postby cncdrive » Sat Oct 09, 2021 5:18 am
Can you please post your mach3 xml settings file?
Postby Berti » Mon Oct 11, 2021 11:54 am
i cant upload the file because it is "identified as a possible attack vector"...
Berti
Postby cncdrive » Mon Oct 11, 2021 12:40 pm
Please ZIP the file.
Postby Berti » Mon Oct 11, 2021 2:04 pm
thanks, now it worked.
Wemas Turn.zip
(24.27 KiB) Downloaded 610 times
Berti
Postby cncdrive » Mon Oct 11, 2021 9:39 pm
Thank you.
I forwarded the issue to my collegue who works on the Mach3 plugin developments.
I'll let you know what he found asap.
Postby Berti » Tue Oct 12, 2021 8:15 am
Berti
Postby Berti » Tue Oct 12, 2021 12:17 pm
cncdrive wrote:Thank you.
I found another intersting thing.
When ive opened the axbb in/out Monitor, i can change FRO and SRO with my potis. But when i close it, Feed and spindle speed doesnt change anymore...
Berti
Postby Berti » Tue Oct 12, 2021 12:18 pm
Also all the poblems stay when using mach 3 turn with my mill.
Berti
Postby cncdrive » Wed Oct 13, 2021 3:22 pm
We have checked your xml file and the issues you reported and the problem is with your xml file.
The issue is that there are illegal characters in it which is because you using a cracked license key.
The solution is to use a proper purchased Mach3 license key.
You can test this with you removing your mach1lic.dat license file from the Mach3 folder and then run Mach3 2 times and after the 2nd time it will run fine.
Return to Mach3/4 Discussions
