I know there is an automated probing routine to set the angle with a touch plate but is there a way to make it pause and ask you to click an ok for next step button so you get enough time to manually move the probe to the second location to be probed? So I'd put it on the bottom left corner, touch off, then have it move over either a set distance or manually jog it over on the x to where the second corner is/bottom right of a workpiece and then you click ok and it then moves in and touches off, working out the angle it's off by?
Thanks.
