Block Delete , Skip
Re: Block Delete , Skip
Postby cncdrive » Wed Sep 22, 2021 12:59 am
No, we did not implement it sorry, but how would it exactly work, like all lines starting with / would be ignored if a "block ignore" switch is switched on by the operator?
Postby dhanger » Wed Sep 22, 2021 2:19 am
cncdrive wrote:No, we did not implement it sorry, but how would it exactly work, like all lines starting with / would be ignored if a "block ignore" switch is switched on by the operator?
Yes, that is exactly how it works. I too have used that feature on industrial machines, and while I don't use it a lot it was nice to have now and then. All blocks needing to be ignored sometimes and not others would be preceded by a '/' symbol. When the operator wants to ignore the blocks a toggle switch on the panel would be turned on, otherwise when the switch is off the blocks are then valid.
dhanger
Users browsing this forum: No registered users and 19 guests
