Erratic spindle speed
Postby zapbrannigan » Tue Aug 24, 2021 7:58 pm
Wondering where to start troubleshooting my spindle which has started spinning erratically, hoping someone can help. When I power it up it does not spin at a steady frequency. It jumps around.
AXBB-E
UCCNC
Huanyang VFD
2,2KW spindle
zapbrannigan
Re: Erratic spindle speed
Postby cncdrive » Wed Aug 25, 2021 4:29 am
I would check if the analog voltage is constant or fluctating when the spindle speed is fluctating, this way you could see if the issue is with the VFD or not, because if the speed is fluctating and the analog input voltage to the VFD is constant then the issue is sure with the VFD.
Postby ger21 » Wed Aug 25, 2021 10:36 am
What exactly is it doing? If it varies up and down by ±1000 rpm, then it's an issue with the VFD. Mine does this exact same thing, and I've seen examples of many other Huanyang VFD's doing this.
The solution for me was to use the Huanyang plugin for speed control instead of analog.
Postby zapbrannigan » Wed Aug 25, 2021 7:05 pm
The voltage is steady so must be the vfd. It was working fine a few days ago...
Where do I get this plug in?
Thanks for replying.
ger21 wrote:What exactly is it doing? If it varies up and down by ±1000 rpm, then it's an issue with the VFD. Mine does this exact same thing, and I've seen examples of many other Huanyang VFD's doing this.
zapbrannigan
