AXBB CNC
AXBB CNC
Postby Peter G » Wed Aug 18, 2021 1:44 pm
Hey Everyone,
I have finished setting up my CNC replacing my Chinese cnc controller with an AXBB-E. Everything works I can stop/start spindle and control its speed. Jog the machine etc. However, I am having an issue with running g code. I can execute G0 commands but not G1 commands if I run G1 X10 Y10 Z0 F300 it does not do anything. I think this has something to do with the feed rate somehow. I have not encountered this issue before. I should mention I am using Mach 4. Any help would be much appreciated.
Peter
Peter G
Re: AXBB CNC
Postby cncdrive » Wed Aug 18, 2021 6:36 pm
Can you try to install a different version of Mach4? Maybe it is a problem with the specific version you using.
Re: AXBB CNC
Postby Peter G » Thu Aug 19, 2021 5:23 pm
Created a new profile in mach 4 fixed the issue
Peter G
Return to Mach3/4 Discussions
