Probing Process Clarification
Postby ejg3855 » Tue Jul 27, 2021 4:06 pm
I have a Bridgeport I've successfully converted to run on UCCNC.
My Z axis is the quill and works entirely in the -Z direction, G53 Z0 being all the way up.
I have a touch probe for setting tool heights in the tool heights dataset. Quick Change Collet allows me to keep the tools fixed.
I also use a basic electrical continuity probe for finding features on parts, simply Z height. I have a plastic tool with a metal center I connect a clamp too. With a known height. Do I enter this as the gauge height ?
The trouble I am having is the proper order of operations and what values I should be setting and seeing.
Example:
I have a 1/4" endmill that when I touch it off on the tool setter is a value of -4.500 ( I enter this into T4), then when I touch off the part (simple probe not with T4) I get a Z value of say -2.5.
Does UCCNC do the math for the Z heights differences between the tools and the gauge and where my Z heights are, or what is the best actions to take here? Im at a loss and tired of crashing my Z into the part.
W
ejg3855
Re: Probing Process Clarification
Postby cncdrive » Tue Jul 27, 2021 9:58 pm
It depends on the probing macro code you will be using.
Postby ger21 » Tue Jul 27, 2021 10:22 pm
You need to be using G43, tool length offsets.
Postby CL_MotoTech » Mon Aug 02, 2021 12:13 pm
Make sure you set Z0 with a tool that has a tool length offset in the tool table. I've made that mistake once or twice.
CL_MotoTech
Users browsing this forum: Google [Bot] and 27 guests
