Hyplugin
Hyplugin
Postby Kenennis » Wed Jul 07, 2021 10:55 am
I am in the process of changing from Mach3 to UCCNC, I am down to fine tuning the system but have run into a problem with getting the VDF to work correctly. I have loaded Hyplugin 14 and configured it with com port 3 Baud 9600. It works fine but somehow the spindle appears to be limited to 11880 RPM. On the start screen it shows under VDF Settings Max Hz400,Min Hz 0,Max RPM 24000 and Min RPM 0. However on the configuration page for the spindle under Spindle Velocity it shows 11880 no matter what I have tried I am unable to get this to change. Everything else works I can speed the spindle up and down with my Pendant or on screen using the + and - buttons or by MDI commands but whatever I try it will not go above 11880 RPM. I would appreciate some help .
Kenennis
Re: Hyplugin
Postby cncdrive » Wed Jul 07, 2021 11:16 am
Why can't you change the max. spindle RPM on the spindle settings page in the UCCNC?
Or you can't change it in the plugin?
Maybe it is set lower in the UCCNC spindle setup and so maybe the plugin does not allow to set it higher in the plugin.
But this is just my idea as I have not used that plugin yet.
Re: Hyplugin
Postby Kenennis » Thu Jul 08, 2021 1:13 pm
After much work I have managed to get the problem sorted out. There must be a bug or a corrupted file some where in the system. I tried a different profile and everything worked as it should so I created a completely new profile and re configured it. I have just run a test cut and everything appears to be working as it should.
Kenennis
Users browsing this forum: Bing [Bot] and 39 guests
