When homing the signals from the limit switches are not considered.
Is there a way to enable this?
Reason is I'm doing a upgrade of an old mill which has +/- limits separate from home switches (located some 1/3rd between limits). If the machine is on "wrong" side of home at start up, it can crash during homing procedure.
Ideally hitting a lim during homing should make the direction change to reach home signal.
I could solve this by using the lim sw as home sw, but thought I might ask for other solution first. Having home 1/3rd between limits makes homing faster with less transport.
Im using UCCNC with a UC300eth + UB1.
