Re installing UC100
Re installing UC100
Postby deckel11668 » Thu May 13, 2021 4:30 pm
I have replaced a computer which was Dying ( everything worked but took ages )
New machine is solid state drive, windows 10, and flies
I tried copying all the software from my old disc using a dock so copied over all uccnc files,,all as they had been working in old machine, but now only works in demo mode
Have reinstalled a fresh copy of UCCNC, down loaded UCx00 driver for automatic install , and copied my licence into the UCCNC folder (it overwrote the previous)
But still only works in demo mode and blue light does not illuminate.
UC100 controller works in mach 3 with all the lights so I am presuming that is OK.
Clearly I am missing something in UCCNC but just cant see what. It could be 15 months since I last used this so I am well rusty , but it did work fine . I cant find any configuration setting which seems to help.
Can anyone help
deckel11668
Re: Re installing UC100
Postby cncdrive » Thu May 13, 2021 5:47 pm
Do you receive a "no valid license key file" message on the UCCNC software startup?
If you do then it is a license key issue.
If you don't then it is something else.
Postby deckel11668 » Thu May 13, 2021 8:26 pm
Didnt get that message
just goes into demo mode
So what might it be
deckel11668
Postby deckel11668 » Fri May 14, 2021 9:57 am
So , as they say , "if all else fails then read the instructions "
These say "To install the license key, simply copy the license key file to the UCCNC installation folder and run the software. The software automaticaly senses the license key in the installation directory and will connect to the device"
Now I do not see a " UCCNC installation" folder, I see a couple of USB installation folders, so where do I paste the license please
deckel11668
Postby cncdrive » Fri May 14, 2021 10:03 am
The installation folder means the folder of your UCCNC installation. E.g. the C:\\UCCNC/ folder.
Postby deckel11668 » Fri May 14, 2021 10:46 am
So as you can see my licence is in that folder !
What do I need to do so that my software works ? Controller works in Mach 3.
deckel11668
Postby deckel11668 » Fri May 14, 2021 11:01 am
No further action needed here .
I Re downloaded the UCx00 drivers for the third time and now it works
deckel11668
