Vista CNC PS4-S
Vista CNC PS4-S
Postby jmm2020 » Sat Apr 24, 2021 10:37 pm
my pendant is not being recognized in the Plugins section...Vista PS4-S that was working fine has just suddenly gone completely missing...the .DLL is in plugins but I don't see anything to enable in the settings...has worked flawlessly in the past and not sure I did anything.
Any thoughts greatly appreciated.
jmm2020
Re: Vista CNC PS4-S
Postby CL_MotoTech » Tue Apr 27, 2021 10:35 pm
Try loading the file on the pendant again. I forget the technical name for that. Then reboot the pc. Also, mine likes to overdraw my USB port, going to a powered hub fixed the issue. Your issue sounds different though.
CL_MotoTech
Re: Vista CNC PS4-S
Postby jmm2020 » Thu Apr 29, 2021 2:41 pm
Check, Check and Check....I tried all...excellent suggestion on Power had me pretty excited with my powered hub sitting on my workstation but still just this odd inconsistency...since it's dedicated to this machine and doesn't have much on it I decided to scrub it and start over, saving just my machine config files, Default.Pro. I was pretty stoked after first startup I had a pendant but when I did a restart alas I was back to square one. I can't even seem to come up with a pattern...I unplug, restart, replace file, dance a jig and then repeat....it just seems very random but again I bring it to the workstation and it loads every time....The machine PC is a nice little unit too...not an Atom or anything but an i5 with 16G of ram and a nice SSD but it would seem to be something in there...not sure where to go from here....
jmm2020
Re: Vista CNC PS4-S
Postby CT63 » Thu Apr 29, 2021 7:21 pm
The PS4-S is defective contact Vista for a replacement. I had the same issue.
CT63
Re: Vista CNC PS4-S
Postby CL_MotoTech » Fri Apr 30, 2021 2:09 am
They do have excellent support, so contacting them is a good idea.
CL_MotoTech
Re: Vista CNC PS4-S
Postby jmm2020 » Mon May 03, 2021 4:41 pm
Excellent bit of news there!....Many thanks I will contact them and grateful I hear yet again about how great they are about supporting their stuff!
jmm2020
Re: Vista CNC PS4-S
Postby jmm2020 » Mon May 10, 2021 12:03 pm
Well to close this out I determined that the computer I was using has some very strange issue with the pendant and it's isolated to this one PC....I had an ancient T5400 workstation I dragged out and loaded everything in and it works repeatedly and uninterrupted with the very same hard drive and thus software config....shame it seemed like an ideal candidate being small form but pretty powerful...Lenovo I5 mini.
jmm2020
Users browsing this forum: Google [Bot] and 52 guests
