Thread milling
Thread milling
Postby MikeM » Thu Apr 29, 2021 7:27 pm
I'm busy planning the wiring to my AXBB controller.
I have only 1 input available before needing an expansion board.
If I add a spindle index sensor would I be able to do thread milling?
Or would I need an encoder with A, B and index channels to be able to do thread milling?
MikeM
Re: Thread milling
Postby Robertspark » Thu Apr 29, 2021 7:40 pm
AB and Z encoder
Re: Thread milling
Postby dhanger » Thu Apr 29, 2021 8:08 pm
Do you mean rigid tapping or thread milling? Thread milling does not require any inputs, I do it all the time without encoders. Just depends on your cam software generating the correct code.
dhanger
Re: Thread milling
Postby MikeM » Thu Apr 29, 2021 8:43 pm
I'd like to do thread milling, similar to single point threading on the lathe.
Not rigid tapping, using for instance a spiral flute tap. I do understand the need for presice spindle position to z-axis movement to be able to do rigid tapping
I will be using Fusion360 for CAD/CAM.
MikeM
Re: Thread milling
Postby dhanger » Fri Apr 30, 2021 3:04 pm
Okay, yeah for thread milling you do not need any additional hardware I/O's or the like. I'm not familiar with Fusion360 but I just googled thread milling for Fusion and got a lot of returns on it. Here's one that looks like a good run-through of it:
https://support.bantamtools.com/hc/en-u ... Strategies
dhanger
Re: Thread milling
Postby MikeM » Fri Apr 30, 2021 4:31 pm
Thank you Dan!
Delighted that I don't need to buy an expansion card and encoder yet.
MikeM
Users browsing this forum: Bing [Bot] and 36 guests
