Continuous Jog Issue
Postby Trooper11040 » Thu Jul 02, 2020 4:04 pm
So I just started using UCCNC 2 days ago, coming from GRBL prior. If I home the machine, zero out all the offset, and go to jog the machine using the continuous function, It will grey everything out, locking out my ability to save a new work zero. When I go into the status screen, it will show jog still lit up red after I am done jogging. Hope that makes sense. If a video is needed, let me know and I can upload one!
Trooper11040
Re: Continuous Jog Issue
Postby cncdrive » Thu Jul 02, 2020 7:23 pm
Interesting, because nobody ever reported this kind of problem.
Honestly I have no idea why is it happening with you, but some questions:
- When this happens is the axis you jogged still counting? (The axis position DRO)
- How do you jog the machine? With keyboard keys? Or with the onscreen buttons? Or with external input triggers?
Also please post your profile file.
And sure, if you can make a video could be also helpful.
Postby Trooper11040 » Sat Jul 04, 2020 9:15 pm
Attached is the profile im using...I will also upload video for you here shortly!
C4Nmini.pro
(35.76 KiB) Downloaded 607 times
Trooper11040
Postby Jasonrm1983 » Sun Apr 25, 2021 1:35 pm
I have the same issue. JOG and RUN stay on
Jasonrm1983
