jog panel keeps flying out on its own
Postby dhanger » Thu Apr 15, 2021 7:21 pm
UCCNC 1.2113
I recently upgraded versions and didn't have this problem earlier. The jog panel keeps coming out on its own--I can look away from the screen for a while and sometimes when returning the jog panel is out. I have the checkbox enabled to disable automatic flyout. Any ideas?
dhanger
Re: jog panel keeps flying out on its own
Postby ger21 » Thu Apr 15, 2021 7:25 pm
Never seen that happen.
Postby dhanger » Thu Apr 15, 2021 7:29 pm
I know, it's weird. For a while I thought it might be a conflict with the new version and my VistaCNC MPG, but I disabled the plugin for that and it kept happening.
dhanger
Postby dezsoe » Thu Apr 15, 2021 8:11 pm
The "new" version is more than a year old. I've started using it before it was released and still use it today, but it never happened. Check your triggers (input triggers and hotkeys): is there any that calls button 770 or 772 (keycode or function)?
Postby dhanger » Thu Apr 15, 2021 8:16 pm
I'll take a look Dezsoe, but I haven't changed my profile in a long time. The only recent change I've made along with the version upgrade is to install the ProbeIt plugin--maybe I should check with Eric if he's gotten any reports about it.
dhanger
Postby dezsoe » Thu Apr 15, 2021 8:21 pm
OK, I have no other idea. Do you have a touch screen? Maybe, that can joke you too...
Postby dhanger » Thu Apr 15, 2021 8:22 pm
dezsoe wrote:OK, I have no other idea. Do you have a touch screen? Maybe, that can joke you too...
Hah, I do have a touch screen, I was thinking maybe I need to clean it LOL.
dhanger
Postby dhanger » Thu Apr 15, 2021 8:23 pm
Maybe I have a fly playing with me...
dhanger
Postby CL_MotoTech » Thu Apr 15, 2021 9:46 pm
My touchscreen occasionally acts up. I just unplug the USB, clean it, then plug the USB back in. Everything goes right back to normal. On really long runs my coolant tends to get out of the enclosure, either via the air or via my fingers, either way when it gets on the screen sometimes things get a little wonky.
CL_MotoTech
Postby dhanger » Fri Apr 16, 2021 6:01 am
Well I may have found the solution, although it doesn't make sense. I've used a wireless keyboard for about 2 years with UCCNC and never had an obvious problem with it, but I went ahead and disabled it and plugged in a corded keyboard. Worked for several hours without having the problem once. I don't know why it would start acting up after this much time, but who knows what evil lurks in the hearts of digital devices. Time will tell I guess.
dhanger
Users browsing this forum: Bing [Bot], Google [Bot] and 24 guests
