v carve pro
v carve pro
Postby jonathanmahnken » Thu Apr 08, 2021 5:02 pm
Will I have trouble working in inches with this program? They only have a post for uccnc(mm)...
jonathanmahnken
Re: v carve pro
Postby mickecarlsson » Thu Apr 08, 2021 8:49 pm
If your UCCNC is setup to work in mm then you can work in imperial in Vcarve and use UCCNC post processor for mm.
mickecarlsson
Re: v carve pro
Postby ger21 » Thu Apr 08, 2021 9:12 pm
You can also very easily create an inch post processor if you work in inches in V Carve, and have UCCNC setup in inches.
Re: v carve pro
Postby charliem » Fri Apr 09, 2021 9:37 am
You can also use the Mach2/3 Arcs inch PP. This what I use and I have no issues.
Regards
Charlie M
charliem
Re: v carve pro
Postby jonathanmahnken » Sat Apr 10, 2021 9:01 pm
Thanks to eveyone. I discovered there is a standard gcode pp in inches for v carve.
jonathanmahnken
Users browsing this forum: Google [Bot] and 23 guests
