Modbus Master
Modbus Master
Postby andyjack38 » Thu Mar 18, 2021 10:33 pm
Hello everyone, I have this problem after creating a serial connection (RTU) and a function I get this message '' The
object reference is not define at an instance of an object '' plz what is the problem
andyjack38
Re: Modbus Master
Postby dezsoe » Thu Mar 18, 2021 11:48 pm
Hello, which UCCNC version and which Modbusmaster version? Can you also upload your profile to check your modbus settings?
Re: Modbus Master
Postby andyjack38 » Fri Mar 19, 2021 12:55 am
dezsoe wrote:Hello, which UCCNC version and which Modbusmaster version? Can you also upload your profile to check your modbus settings?
The UCCNC version is :1.2113
For the profile How do I make the upload
andyjack38
Re: Modbus Master
Postby dezsoe » Fri Mar 19, 2021 9:14 am
I've just wrote a description: How to find version numbers and the profile.
Re: Modbus Master
Postby andyjack38 » Fri Mar 19, 2021 11:26 am
dezsoe wrote:I've just wrote a description: How to find version numbers and the profile.
HI, I understand, i know where the infos are that you want it is how I do send them to you. I see at the bottom Option Upload attachment
andyjack38
Re: Modbus Master
Postby andyjack38 » Fri Mar 19, 2021 1:02 pm
TO Dezsoe; please show me how i send profile and screen capture of uccnc
andyjack38
Re: Modbus Master
Postby dezsoe » Fri Mar 19, 2021 5:10 pm
Nothing special. Press Post reply, scroll down and press Upload attachment (1), press browse (2) to select the profile, press Add the file (3). Write some message as usual (empty message will not work). Press preview to preview or submit to submit.
Re: Modbus Master
Postby andyjack38 » Fri Mar 19, 2021 6:55 pm
Hello , I hope I done ok
Bought the controller with licence from a friend in Belgium last summer if you could change ownership to my name (Andre Proulx) it would be fine. thank you for helping me and good day
ANDY_CNC.pro
(37.78 KiB) Downloaded 509 times
andyjack38
Re: Modbus Master
Postby dezsoe » Fri Mar 19, 2021 7:50 pm
There's no modbus setting in your profile. Did it crash while you tried to configure it? Also, the ModbusEZ plugin is enabled on COM3. Maybe, the problem is that both plugin wants to use the COM3? Try to disable ModbusEZ and after restarting UCCNC try modbus master again.
