by cncdrive » Tue Jan 09, 2018 4:41 pm
Yes, that's correct. The UCCNC does not have formulas to correct the screw pitch differences.
However that part of Mach3 is really buggy, so I would not use it with Mach3 either.
It's fine that servos can't loose position, but you will still see the results on the workpiece of the bugs how mach3 handling the correction,
because however your axes will not loose steps, but jumping accelerations will cause the machine to shake...
So, I think that you should look for something else than UCCNC or Mach3 if you successfully want to do pitch correction on the machine.
I don't know though if there is any cheaply available softwares out there which correctly handing this?!
