regen toolpath ?
regen toolpath ?
Postby gurusonwheels » Thu Mar 11, 2021 6:33 pm
i come from mach3 and used to have to click "regen toolpath" everytime
you brought in a new toolpath and had setup your work offsets .
i dont see a regen toolpath button in uccnc anywhere ..
how does it work in uccnc ?
gurusonwheels
Re: regen toolpath ?
Postby cncdrive » Thu Mar 11, 2021 9:41 pm
There is a "reload" button next to the toolpath viewer.
Postby gurusonwheels » Thu Mar 11, 2021 9:56 pm
Was wondering if that's what that button did
Or was there just incase you edited the file and wanted to reload the file .
Thank you for clarification
You can see how reload and regen can have different meaning to folks
gurusonwheels
Postby cncdrive » Thu Mar 11, 2021 10:08 pm
The reload button reloads the currently loaded file.
The naming "regen" is wrong/missleading in Mach3, because it actually reloads the file just like what the reload button does in the UCCNC.
When you editing the loaded g-code file with the UCCNC file edit function and changing anything in it's content then the UCCNC automatically reloads the file when you finish the editing.
Postby gurusonwheels » Fri Mar 12, 2021 12:36 am
cncdrive wrote:The reload button reloads the currently loaded file.
strange . when i click regen in mach3 i can see the layout actually change on the screen
after i set the work start point.
before
after pressing regen ....
not a programmer but it appears to have change the location to the same as the spindle work start .
gurusonwheels
Users browsing this forum: Bing [Bot] and 43 guests
