cncdrive wrote:A limit switch has 2 poles, it switching through a Voltage.
The question is what your limit switches are switching through?
You could switch through the +24Volts and then you connect the limit switch wire to the Input+ and connect the 24V0 (ground of the 24V PSU) to the Input-
Or you could switch through the 24V0 and then you connect the limit switch wire to the Input- and connect the +24V to the Input+
Both method works and both are drawn and described in the AXBB-E manual.
I'm sorry, but if you don't understand anything what I'm writting then I don't know how I could help you.
ok i got all axis working except a-axis . have not attempted .
got home switches or limit switches ... not sure which they are . they are working right now as home switches .
the limit switches on this machine is 6 micro switches for the 3 axis .
1 wire common to both switches on one pole example z- and z+ both use same wire one pole .
the other wire on all switches are all wired to 24v0
so im not sure if i can use these as limit switches or not ?
i have the probe now working also .
and the emergency stop button .
i have homed all axis and it works
the spindle works . but i can tell its not running at the speeds i set it to. not sure what needs to be configured for that .
i remember having to do some kind of motor tuning in mach3 ... not sure if this is something in uccnc or not .
getting there !
thanks for hanging in there with me .
also have my WHB04B-6 working as well .
i have noticed every time i close uccnc i get this error .
i have noticed that the spindle while running will only run like 3-5 secs and stop
with ext e-stop triggered.
