UC100 Lights on but not moving CNC table
Postby vergarag » Sun Mar 07, 2021 8:01 am
Hi there, I need your help please!! I have a CNC 4'x8' table that bought 5 years ago... it is running with Mach3 and UC100 and breakboard MX4660.
Here is my problem... As I mentioned before it was working great for 5 years... till Last Wednesday, I moved the table from one corner to an other on the same room, but when moving it the dolly we were using collapsed, so it hit the floor, it was about 6" from the floor.
Next day I plug the PC using the UC100, I have green and blue LED lights on and steady... but the table doesn't move at all... I cant move the axis by hand so Im assuming motors had power... when I press the arrows and pgUp and pgDown the axis on the screen of Mach3 moves,.. I also run the last code of gcode I use before I unplugged the CNC and the Mach3 display also moves... but not the table.
I need you help as I have a lot of cuts to do for a client. I am guessing is not a software or setup issue as it was working fine... PC is not connected to the internet so no way to attach the issue to a firmware update... I ordered a new UC100 thinking that it might be the issue (I will receive it by Wednesday), but again,.. green and blue LED are on and steady now... but not sure if even that the lights are on,... the UC100 is communicating with the breakboard.... any suggestion what to check or what to do? Thank you in advance!!!
vergarag
Re: UC100 Lights on but not moving CNC table
Postby ger21 » Sun Mar 07, 2021 12:50 pm
Is the UC100 plugged directly into the MX4660, or is there a cable between them? Check that connection.
Postby vergarag » Sun Mar 07, 2021 3:47 pm
ger21 wrote:Is the UC100 plugged directly into the MX4660, or is there a cable between them? Check that connection.
Hi !! Good day! The UC100 is plugged directly into the MX4660. Well is just on mini gender adapter. I removed it and found that that one pin (25th) was missing.. I bought one, change it but nothing. Seems like that pin was removed before as I didn’t find it in the UC. Thank you for you help... I’ve had been pulling my hair out trying to find out why is not moving.. :cry:
vergarag
Return to Mach3/4 Discussions
