Keyboard emulator for calling I/O Hotkey triggers
Postby ChrisG » Thu Mar 04, 2021 4:56 pm
Im using a keyboard emulator which correctly outputs ascii characters. As a test they show up properly in the MDI text field.
I am trying to call function code 220,221 and 222 which calls the axis select for an MPG handwheel encoder.
The hotkeys on the host laptop do select the chosen MPG axis. Why wont the emulated keystrokes change the MPG axis selection as expected?
Makes no difference if the emulator uses ascii chaacters, hex, or letter numbers.
Any ideas?
ChrisG
Re: Keyboard emulator for calling I/O Hotkey triggers
Postby dezsoe » Fri Mar 05, 2021 11:08 am
Maybe, you have some plugin or macroloop enabled which also tries to change the MPG axis. Check the enabled plugins and macroloops.
Users browsing this forum: No registered users and 34 guests
