Can't get slave axis to work
Postby Blackslacks » Tue Feb 16, 2021 12:28 am
Hello Ive been using Mach3 for my plasma. I bought UCCNC some time ago but I cant get the slave axis to work. I'm want to use A axis as the slave to Y. If I load Mach3 all axis work as they should, load UCCNC and the slave motor doesn't run. I'm using a UC100 motion controller. If I unslave I can jog the A axis. I imported my Mach3 profile into UCCNC.
Enclosed is my profile. Thanks in advance
Plasma.pro
(34.56 KiB) Downloaded 378 times
Blackslacks
Re: Can't get slave axis to work
Postby charliem » Wed Feb 24, 2021 10:49 am
What are you using to drive the stepper motors? do you use a breakout board?
Regards
Charlie M
charliem
Postby CT64 » Wed Feb 24, 2021 3:13 pm
Importing a Mach 3 profile is not always an exact process. I found when I imported my Mach 3 profile I had to change several I/O and motor settings.
CT64
Postby Blackslacks » Sat Feb 27, 2021 12:47 pm
charliem wrote:What are you using to drive the stepper motors? do you use a breakout board?
I'm using a Gecko G540 and I'm using the same motor pin numbers in UCCNC as in Mach3.
CT64 wrote:Importing a Mach 3 profile is not always an exact process. I found when I imported my Mach 3 profile I had to change several I/O and motor settings.
Can you tell me which ones you had to change so I can try them. I've gone over it and can't see anything obvious.
Blackslacks
Postby charliem » Sat Feb 27, 2021 2:24 pm
Hey Blackslacks,
OK I use the same setup (G540 and UC100) and I had a router that I had Y slaved to A. I had everything set the same way and I did not have any problems.
Sorry I was unable to help you sort this. I am not seeing anything wrong.
Charlie
Regards
Charlie M
charliem
Postby Blackslacks » Sat Feb 27, 2021 3:46 pm
OK Charlie Thanks for looking. I have a question though. If I have A slaved to Y, and I jog the Y axis, should the movement be seen on the A DRO? I 'm going to reinstall and start a new profile from scratch and see what happens.
Blackslacks
Postby charliem » Sat Feb 27, 2021 4:12 pm
I don't think so. At least not that I can remember. let me experiment with something and I'll get back to you.
Regards
Charlie M
charliem
Postby charliem » Sat Feb 27, 2021 4:50 pm
Ok this is what I did, I loaded your profile into my version of UCCNC.
I noticed that ESTOP and charge pump were set to 0.
I set ESTOP to Pin 15 and Port1 and Charge pump to pin 16 and port 1 and pressed enter after every entry. I saved settings and then applied settings.
I have Y and A axis moving as they should. and to answer your question from before the A axis dro does not read when A is slaved to Y and Y is in motion.
I hope this helps.
Regards
Charlie
Regards
Charlie M
charliem
Postby CT64 » Sat Feb 27, 2021 6:40 pm
I'm using a Gecko 540. I had to change to Estop and charge pump inputs. Also the "Y" axis stepper direction input had to be changed. For some reason those I/O setting didn't get imported from Mach 3.
CT64
Postby Blackslacks » Sun Feb 28, 2021 6:03 pm
That did it! Thanks everyone for helping me out. I took a quick look through the manual and couldn't find anything on selecting active low for the master axis step and direction. Anyway thanks again.
Rae
Blackslacks
Users browsing this forum: Bing [Bot] and 42 guests
