Limit Switch problem
Postby warrick4 » Thu Feb 25, 2021 10:06 pm
I am trying to set up my limit switches but failing. They are NPN NO proximity sensors.
The switch lights up itself when activated, the AXBB-E Led lights up when activated, but the UCCNC software shows the pins as triggered and lit up regardless of whether the sensors are being activated or not.
I cant take it out of reset unless I disable the axis, switch it to signal low, or set the pin and port to zero. Once that is done it obviously doesn't work either!
Am I missing something?
warrick4
Re: Limit Switch problem
Postby rajjinator » Mon Mar 08, 2021 9:24 am
Are your limits set up as N/C in the software, thus triggered permanently?
rajjinator
Postby sn4k3 » Thu Mar 11, 2021 11:13 pm
Read this post to end: viewtopic.php?f=4&t=3009&p=22664
sn4k3
Users browsing this forum: Bing [Bot] and 31 guests
