New PC
New PC
Postby naijin » Thu Feb 11, 2021 2:26 am
Hi there, just swapped computers on my home made cnc router and I can not move any axis at all, I have an AXBB-E controller, UCCNC Ver 1.2111 installed same as old pc, copied the macros folder and profile from old pc
every thing light up on the AXBBE , the motor drivers have power, the motors are energised, but when the up down left or right axis buttons are pressed the tumblers on the screen show that the axis are moving but there is no movement on the
gantry, any infoe or ideas are most gratefully appreciated ;) :?:
Nick
naijin
Re: New PC
Postby cncdrive » Thu Feb 11, 2021 2:55 am
If the blue LED on the AXBB-E is turned on when you running the UCCNC software then the AXBB-E is up and running without any problems.
Maybe you not running the correct profile file with the proper settings for your machine?
Or maybe the connection between the AXBB-E and your motor drives is not OK?
Re: New PC
Postby naijin » Thu Feb 11, 2021 3:37 am
Thank you for the quick reply, I was having one of those senior moments :oops: :oops: I forgot to reset ports and pin settings....all is well now :D
Cheers
Nick
naijin
Users browsing this forum: Google [Bot] and 25 guests
