Noisy steppers
Noisy steppers
Postby pless84 » Tue Jan 12, 2021 7:48 pm
I have retrofitted a Shopbot PRCAlpha with AXBB-E.
From another setup I have steps per unit and when I input them the steppers run smoothly but not accurate, when I do the calibration via the calibrate button I get a much lower number and the steppers make alot of noise but it is now accurate.
Where should I adjust?
pless84
Re: Noisy steppers
Postby cncdrive » Wed Jan 13, 2021 11:22 pm
The steppers have different noise with the different calibration values because the different calibration will run the stepper on different speeds and steppers usually make different noise at different speeds. This does not have anything with the motion controller or the software.
If your steppers are noisy then try to use a higher microstep mode on the stepper drive.
Users browsing this forum: Bing [Bot] and 13 guests
