Solidworks Post for UCCNC does not work
Postby jbknudsen » Tue Dec 15, 2020 6:59 pm
All,
New to this forum. I have been using Solidworks to design and save files to DXF to import into Ventricut, set up the tools and make the paths. Then I post so the UCCNC software can communicate with the Stepcraft machine.
- Stepcraft 600
-Solidworks 2020
-UCCNC controller and 100 in the Stepcraft machine
-mach II/III as supplied from Ventricut.
Ventricut, UCCNC and Stepcraft have all come bundled.
I need to post from Solidworks so I can be more efficient and remove the ventricut process. It is a total pain in the back side.
When posting from Solidworks, neither the mach II/III (with or without G54) works.
All vendors are pointing fingers at the other vendors. I need someone to help with this.
What is required and or the best way to post from solidworks to UCCNC????
Attached are both files Solidworks file does NOT work, Ventricut does.
Thanking all yall in advance,
-Jay
Ventircut file.txt
This file works on the UCCNC controller and the Stepcraft 600 machine
(27.19 KiB) Downloaded 489 times
jbknudsen
Re: Solidworks Post for UCCNC does not work
Postby frez1001 » Wed Dec 16, 2020 5:08 pm
What dosn't work about it?
I would have to look more cause I have barely used it but pay attention to the post processor. I think i used a FANUC type exporting to a .nc file. It will take a few days to check but i will look. Im using uccnc generically.
frez1001
Postby jbknudsen » Wed Dec 16, 2020 6:11 pm
Frez1001,
Thanks for the reply. Both files load, the ventricut works great. the solidworks seems to be wanting to start from 0,0,0 of the machine. It will not run. Limits are reached as soon as I attempt to run the file.
My perfect goal is: 0,0,0 next to my stock on the jig (not at machine 0,0,0) and to have the program actually run on the machine. The ventricut file works great, would love to be able to duplicate in Solidworks post to UCCNC.
Thank you in advance,
Jay
Preview of loaded Ventricut file
Preview of loaded Solidworks file
Ventircut file.txt
Post from ventricut mach II/III
(27.19 KiB) Downloaded 470 times
Solidworks file.txt
Post from Solidworks mach II/III
(9.29 KiB) Downloaded 490 times
jbknudsen
Postby frez1001 » Wed Dec 16, 2020 6:53 pm
what happens if you delete line
N6 G90 G00 X62.733 Y-14.844
frez1001
Postby jbknudsen » Wed Dec 16, 2020 7:01 pm
Hey Frez1001,
Same thing.
jbknudsen
Postby frez1001 » Wed Dec 16, 2020 7:18 pm
Attached is a file that works with my setup. its direct from solidworks.
does this load properly in yours?
bar.txt
(27.13 KiB) Downloaded 518 times
frez1001
Postby jbknudsen » Thu Dec 17, 2020 12:09 am
Thanks for the file, No, it does not work. It comes in as a line.
Unfortunately I am not sure what approach to begin with. Solidworks setup, posting, UCCNC, Stepcraft???????
All suppliers are pointing to other entities, of course. :-/
Thanks again,
-Jay
jbknudsen
Postby Vmax549 » Thu Dec 17, 2020 1:01 am
Solid works is working just fine. The problem is you have no idea where your Machine home position is. That long line is from the machine returning back to the Machine home position. There are 2 lines at the end of the file that contain G28. Remove those lines BUT make sure teh Z is up away from the material. See if that does not look better.
IF you are going to use a Gcode machine you really need to learn how to read the basic Gcode. It is extremely simple it is like talking to a 3 year old. It can really only do 2 things move in a straight line and move in an arc.
Just a thought , (;-) TP
Vmax549
Postby Vmax549 » Thu Dec 17, 2020 1:08 am
IF you want SolidWorks to fix the post simply tell them to remove any references to G28.
(;-) TP
Vmax549
