Hi all, have a bit of an issue not too sure if it's a bug or on my side.
I am running a uc400eth on version 2,112, (I realise this is a test version so it could possibly be the problem).
The system has been running flawlessly for as long as I have been using this test release but occasionally at the start of loading a new g-code file and pressing cycle after zeroing, the machine will rapid to random x- y positions and then return to the zero point and start the job as usual.
This problem is not g-code specific as it usually only ever occurs when rezeroing and loading different g-code files.
I am running a custom toolchanging macro but as I stated, this occurs in the beginning of the file, before an m6 or m31 is even called.
I am also running the uccnc atc arcs post processor.
Does this issue seem like a bug that a test release would create or could it be something else going on?
Any help will be greatly appreciated.
