Incorrect G54-G59
Incorrect G54-G59
Postby zerodivide » Thu Oct 01, 2020 9:26 pm
Apparently G54-G59 codes can not be in the same line as XYZ codes.
Now working Example:
G55 (Where Offsets are x-9999 y -9999)
G54 X0 Y0 (Machine still in G55 will try to move axis. This will fire the overtravel error)
But this works:
G54
X0 Y0 (this is fine)
Why this matters: most CAM software by default generate code like: G0 G90 G17 G54 X.. Y..
Which will fail or crash the machine if the current offset is different from the programmed one.
zerodivide
Re: Incorrect G54-G59
Postby dezsoe » Fri Oct 02, 2020 6:29 am
Yes, it is a known issue, the order of execution of the words in one line is wrong.
Postby zerodivide » Fri Oct 02, 2020 12:04 pm
Is it going to be looked at?
Because it also seem to affect this one:
G90 G0 Z1.0
G28 G91 Z0
- instead of sending Z axis home it moves all axis to zero.
I have edited a post processor, so it's not an issue any more but it did give me a scare when machine started to rapid into a corner. I can't be the only one it happens to.
Depending on where home is it could mean broken tools or crashed machine
zerodivide
Postby cncdrive » Fri Oct 02, 2020 2:19 pm
Yes, the G54, 55 etc to other g-code modals priority in a single line will be looked into and will be corrected.
The G28 G91 Z0 is errorous code by standard, so with this the issue is the g-code not how the UCCNC interprets it. The G91 should be before the G28 like G91 G28 Z0, but we will look into it, will compare how other softwares interpret it. But the issue is that the UCCNC interprets it as if G28 has no word parameters, because there are no words but another G-code after the G28 and the G28 without parameters homes all axes.
Postby zerodivide » Fri Oct 02, 2020 7:16 pm
Thank you!
If it helps you out, I tried to shuffle it like so: "G91 G28 Z0" (even though the spec says the order of codes in a block does not matter) and it did not change the behavior.
Again, thanks for looking into it.
zerodivide
