Fusion UCCNC Post Z Axis
Postby limited660 » Wed Jun 24, 2020 12:21 am
I'm trying to use the UCCNC post for plasma and I'm not getting any Z axis moves, is there a way to enable Z axis in this post?
limited660
Re: Fusion UCCNC Post Z Axis
Postby limited660 » Wed Jun 24, 2020 1:31 am
Well found it myself. If you search the post for "if (jetMode) {" you can comment out "zOutput.disable();" and enable Z axis moves in the post.
If you prefer to just use a post, I've attached one where I have added a property called "Use Z axis - Jet Mode" where you can turn this off/on. You will need to change extension of file from txt to cps.
uccnc.txt
(58.59 KiB) Downloaded 579 times
limited660
Return to CNC Plasma
