LED 268
LED 268
Postby laki » Wed Jun 03, 2020 10:48 pm
Can someone check, please?
UCCNC ver 2113, default 2019 screen set.
On the main screen, the Led 268 (Softlimit active) remains on if you use more than 3 basic axes (x, y, z) and if the enable soft limits field is checked. The soft limits function itself works properly, but the LED 268 is always on.
On my machine, the B axis is configured as a slave for the X axis and the LED 268 is constantly on, even though the machine is not even close to the set soft limits.
laki
Re: LED 268
Postby cncdrive » Wed Jun 10, 2020 3:29 pm
Dezsoe,
Please verify if this problem exists.
Re: LED 268
Postby dezsoe » Thu Jun 11, 2020 3:01 pm
Hi guys, I could not reproduce the issue. (I tried with demo and real AXBB-E, B slaved to X.)
Re: LED 268
Postby laki » Thu Jun 11, 2020 5:04 pm
Hi Dezsoe,
Upravo sam probao AXBB, demo mode
Molim te pogledaj snimak
[youtube<iframe width="1280" height="720" src="https://www.youtube.com/embed/iTYa2FatwBU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>][/youtube]
laki
Re: LED 268
Postby laki » Thu Jun 11, 2020 5:06 pm
laki
Re: LED 268
Postby dezsoe » Thu Jun 11, 2020 6:45 pm
OK, I got it. If the soft limit is the same as the home position and you set a slave then it will set the LED on.
Re: LED 268
Postby laki » Thu Jun 11, 2020 7:25 pm
You can set the soft limit to any value, it does not have to be the same as the home position. If you turn on the slave axis, the LED 268 will remain on.
laki
