UC300ETH-5LPT and Relays Configuration Help
Postby lloxley016 » Sat May 30, 2020 6:19 am
hello, ;)
im newbe
Need some with uc300eth-5lpt. I want to temporary use (CNC Spindle Kit 500W Air Cooled 0.5kw Milling Motor + Spindle Speed Power Converter), but
don't know how to wire up this with a relay. i hive a +5v replay module and a +12v relay module. I'm not sure which one to use without burnout UC300.
Because the breakout is +5v output signal, Know sure if the +5v relay work configure. So i would like some advice before attempting to try this configuration. In the UCCNC software for the Spindle NO-> set to PIN 14 / PORT 2. didn't try this Yet!., need to make sure.
Will I really appreciate the help.. Thanks :D
This is my diagram wirning Now. Picture below:
lloxley016
Re: UC300ETH-5LPT and Relays Configuration Help
Postby ger21 » Sat May 30, 2020 1:44 pm
Use the 5V relay board, with Pin 1 to activate it. You don't show the other side, but two of the three terminals should go to the 5V power supply.
Postby lloxley016 » Sat May 30, 2020 4:12 pm
ok, :)
picture of the 12v relay and 5v relay.
both are the same, but one is 5v trigger and other is 12v trigger.
5V One Channel Relay Module Relay Switch with OPTO Isolation High Low Level Trigger.jpg
5V One Channel Relay Module Relay Switch with OPTO Isolation High Low Level Trigger.jpg (15.93 KiB) Viewed 4615 times
lloxley016
Users browsing this forum: Bing [Bot] and 4 guests
