software limits reached
Re: software limits reached
Postby doncraig » Sat May 02, 2020 3:39 pm
@laki, I carried out your instructions but the UCCNC still loads with the Profile: Default and I have to go to Settings > Profiles and change to the Stepcraft profile I have applied and saved but it always opens in Default. Where have I gone wrong ??
doncraig
Postby laki » Sat May 02, 2020 3:54 pm
Right-click on the desktop shortcut UCCNC, go to properties and under Target add \ UCCNC.exe / p Stepcraft1_Model420
I think that we already talked about this :)
"I have right clicked on Properties on the desktop icon and change the target as suggested and the programme now opens with the RUN screen showing Profile: Stepcraft1_Model420.
SUCCESS AT LAST."
laki
Postby doncraig » Sat May 02, 2020 6:19 pm
Hi laki, this is what I have in my files. Is this ok ?
doncraig
Postby laki » Sat May 02, 2020 6:41 pm
Hi Don,
Yes that's fine.
Replace this file with the file I sent you.
The third image refers to the old installation.
laki
Postby doncraig » Sat May 02, 2020 7:26 pm
@laki, this is the file you sent me ??
Stepcraft1_Model420.pro
(34.09 KiB) Downloaded 513 times
doncraig
Postby laki » Sat May 02, 2020 7:56 pm
EDIT I have tried to set the Y axis 'Homing backoff' but it won't let me enter a negative number.
Yes that's that profile.
Start the program, go to settings, axes setup and
in setting for the Y axis you should see this:
laki
Postby doncraig » Sat May 02, 2020 8:05 pm
@laki, I have lost the plot here. I seemed to have missed some posts or something else has happened. Can I start this thread in the morning again after I find out what is happening. I think I was editing a post and it timed out.
take care
Don W
doncraig
Postby doncraig » Sun May 03, 2020 12:45 pm
laki wrote:Right-click on the desktop shortcut UCCNC, go to properties and under Target add \ UCCNC.exe / p Stepcraft1_Model420
SUCCESS AT LAST."
I am sorry laki but this doesn't happen now.
When I start UCCNC it opens in Default and I can go to Settings > Profiles and change it and Save it and Run it, but when I shut down it reverts back to Default and I have to restore it again.
This morning I deleted the 2113 Folder and started again. I have carried out your instructions and clicked the desktop icon. UCCNC has started and it says Profile Default on screen. I go to Settings > Profiles I get the screen I show here, I cannot see a 'Select Screenshot' button. Will I need to delete and re-install ??
take care
Don W
doncraig
Postby ger21 » Sun May 03, 2020 1:05 pm
That's not what his instructions said.
Postby doncraig » Sun May 03, 2020 1:37 pm
@ger21, sorry I did not make that clear. I should have said I deleted the folder 2113 and reinstalled according to his instructions "including setting up the desktop icon". I have done as laki suggested and on't get the result so I may have missed something somewhere
take care
Don W
[/quote]
doncraig
Users browsing this forum: No registered users and 29 guests
