eabrust wrote:Delco,
Thanks for posting the screenshot, it is not loading properly for you for some reason. The controls in the 'right column' should be aligned with the abort button on the right side.
Here is a short video of how it should load, and this is how it loads for me, every time on both Windows 10 and windows 7. I also tried playing with screen resolution and screen scaling, and wasn't able to duplicate it looking like that.
Can you tell me anything about your screen resolution, what version of windows, etc you are using ?
I've also noted that sometimes when I compile the plugin, it will look weird for me (sort of like what you show, but not exactly the same), but if I just recompile it, it will then look fine. Not sure if Vis. Studio glitch or what, but apparently I can't use the fact it loads fine for me to verify it will load fine for everyone else yet..., so thanks again for your help pointing it out.
I do have txt scaling set higher on both machines though
