Autoleveler Plugin.
Re: Autoleveler Plugin.
Postby thegreatwaldo » Tue Feb 18, 2020 1:27 pm
I would imagine it would be quite useful for carving a design on a curved uneven surface.
Cheers.
Andrew
thegreatwaldo
Postby Robertspark » Wed Feb 19, 2020 6:40 pm
Postby eabrust » Tue Mar 10, 2020 12:19 am
cahit wrote:Hello people,
here an update of development new autoleveler.
cheers
Cahit,
Nice updating to the Autoleveler plugin, you should note that this version can quickly flip and mirror gcode, as well as rotate it and dump it strait into UCCNC. Very handy.
I need to learn to use the OpenTK/GL type graphics! really nice work!
Postby Demusman » Wed Mar 11, 2020 7:15 pm
Decided to give this plugin a try. Didn't go so well.
First, what are all the settings? There's really no clear way to tel for sure and it was asked in here but not really answered.
Second, I zero x,y and z ( x and y are lower left corner), load my gcode from the plugin to uccnc, then click run and the spindle goes to the left, off the workpiece, and strarts to probe??!!
What did I do wrong here? Do I have to position the spindle in the middle of the workpiece? Doesn't seem logical since it's using the gcode with zero in the lower left.
Demusman
Postby Demusman » Sat Mar 14, 2020 10:25 am
@cahit
Any chance you can answer my previous questions??
Demusman
Postby cahit » Sun Mar 15, 2020 10:02 pm
@Demusman,
the plugin is not finished yet. when it is finishend i will add a manual for it.
cahit
Postby Demusman » Mon Mar 16, 2020 11:52 pm
In the mean time, can you at least answer the questions?
Demusman
Postby cahit » Tue Mar 17, 2020 10:57 am
@Demusman
probing altitude is the height travel to first point of probing here in green color.
red color is the min max and step settings for this fields in case of using mm or inch.
probing depth is if you forget to attach the probe the tool goes max below zero.
probing speed is the speed that the tool down to pcb.
travel altitude is the travel height form point to point
travel speed is the speed between traveling from point to point.
segment length is if you have a long path across a view points that cuts the line in parts for
following the probes.
i am not sure what you do wrong.. can you make a video or i can watch with teamviewer to help you out of this problem.
Cahit Ates
cahit
Postby 1.21gigawatts » Fri Apr 10, 2020 1:36 am
Using autolevelerCA v3.031 and UCCNC 1.2111, I have a problem. My system is in inches, so I had to modify the limits and the settings (see below) to what I thought were reasonable values. The results are, pretty well broken.
Here is the board as output from CopperCAM loaded and ready to run:
Here are the settings:
and here is a clip of the output as sent to UCCNC:
Am I doing something really wrong? Where do I go from here?
1.21gigawatts
Postby cahit » Fri Apr 10, 2020 6:46 am
hi,
you are doing nothing wrong. this is a development version, it is not finished yet.
cahit
