I've been back working on a few touch probing related plugins since getting UCCAM copy working. I figured that with some of the questions Keith was asking relative to digitizing ( http://www.forum.cncdrive.com/viewtopic.php?f=4&t=2383#p18893 ) made this a good opportunity to show what I'm working on despite it being no where near ready for anyone to use...
I had been wanting to port the 'ProbeIt' wizard from Mach3 code into UCCNC for some time, however almost every single probe routine in it is dependent on doing a combined X/Y G31 probe, which still isn't supported (insert sad face here ). But I was playing around a few weekends ago and came up with a way to create a simulated multi-axis G31 command using the 'Jog Safe Probing' feature that UCCNC has. After a little testing, came up with something to try and make it work....
Below video shows the first stages of porting ProbeIt code into UCCNC as a plugin, and running a probe calibration table for angles between 0 - 360 in increments of 10 degrees.
It has a long way to go, but it's a start!
In the end, I want to replicate all the features ProbeIt for Mach3 had and add a bunch more since programing in .Net is so much more powerfull than Mach3 wizard code allowed. Some things on the to-do list:
profile tracing-save direct to DXF
manual jog against part - save direct to DXF
Include DXF recording of all basic probe routines (edge, center points, sides, etc)
Incorporate 3d surface scanning (I'm pulling in the 'probecloud' plugin I started a while ago, and will build upon it)
thanks for looking,
