How to tell UCCNC where the machining limits are?
Re: How to tell UCCNC where the machining limits are?
Postby delta21@gmail.com » Tue Jan 07, 2020 12:02 am
ok, but how do I do it? I really need help with this. Some step by step...
delta21@gmail.com
Postby delta21@gmail.com » Tue Jan 07, 2020 12:09 am
See this. The yellow cone travels all back to the left.
This box is totally off.
What am I doing wrong?
delta21@gmail.com
Postby cncdrive » Tue Jan 07, 2020 12:11 am
Your g-code file contains those movements.
Postby delta21@gmail.com » Tue Jan 07, 2020 12:12 am
The box in white lines should be half the size.
And the part to be cut should be on the left side.
So what do I do wrong?
delta21@gmail.com
Postby cncdrive » Tue Jan 07, 2020 12:14 am
Your g-code file contains those movements. Your g-code file is wrong is what you doing wrong.
Postby delta21@gmail.com » Tue Jan 07, 2020 12:17 am
So why is it working with Shapeoko and Haas machine properly … no issue there.
I believe I don't have the homing right.
The White box is too big.
And the machine doesent understand where the part sits. So is there any explanation about this?
Could that be?
delta21@gmail.com
Postby cncdrive » Tue Jan 07, 2020 12:21 am
The white box shows around the area where your g-code moves the axes. From the UCCNC side it is that simple.
Postby delta21@gmail.com » Tue Jan 07, 2020 12:26 am
Okay.
How can I set home for ZX and Y? Sorry but I am in the basics here.
delta21@gmail.com
Postby cncdrive » Tue Jan 07, 2020 12:28 am
You press the home button right next to the axes DROs on the run screen.
Postby delta21@gmail.com » Tue Jan 07, 2020 12:33 am
There is a yellow cone and a blue cone.
The yellow must be the cutter.
What is the blue one?
delta21@gmail.com
