Mach3 and UC300ETH Homing Speed Issues
Postby msimpson99 » Wed Dec 11, 2019 9:39 pm
I have an issue that when I home a system that is using Mach3, Windows 10 and a UC300ETH it homes very slowly. Even if the home sped is set to 100% it is still pretty slow. It is as though the homing speed set is not a percentage of the Rapid Speed.
Note this is not the case when using the UC100, the home speeds work as expected. I am about to write-up a step by step guide on my Website and it looks like I have to indicate to the readers that the MAch3 plugin for the UC300ETH has a bug and they must set the home speed to 100%. My worry is that if this bug gets fixed the machine will most likely crash at 100% speed when homing.
Any kind of insite would be helpfull.
msimpson99
Re: Mach3 and UC300ETH Homing Speed Issues
Postby msimpson99 » Wed Dec 11, 2019 10:03 pm
I was using the UC300ETH mach3 plugin version 1.02. I installed UC300ETH mach3 plugin with version 1.013 and the problem does not exist. The version 1.02 plugin was installed when I installed the via the installer. N
Now I have to tell my readers to install the 1.013 as the 1.02 has the bug.
msimpson99
Postby Chrismolloy » Thu Apr 01, 2021 2:28 pm
Do the cnc drive folks follow these posts? Will they fix it?
Where do I find 1.013 version?
Chrismolloy
Postby ger21 » Thu Apr 01, 2021 3:57 pm
In Mach3, in the plugin config, it'll automatically download the latest version for you.
Return to Mach3/4 Discussions
