I guess the advantage of two products is additional licence fee potential (I'd pay it.... I don't want yet another motion controller....)
I've thought about swapping axis about so it's akin to a vertical mill.... That way threading should work ok
Feed per revolution / surface speed correction doesn't though without the hack in attempted...
I guess you could use the underlying code and just enable mill / router / plasma with one licence, and turn / rotary axis with another licence code
I've been looking at PMDX-414 for a mach4 lathe compatible (spindle sync/ encoder input) (i still have my mach4 licence so it's just the motion controller cost)
I like the availability of the turn wizards in mach4
I looked at the centroid acorn.... The glitch i saw was the required minimum pc specification ..... Single core performance of 1500 and greater.
https://www.cpubenchmark.net/singleThread.html ... For me that would mean another pc upgrade.... Plus motion controller... Plus lathe Pro software....plus another learning curve...
Linux CNC lathe lacks the wizards.... hence not going that way for the moment, but it have a working RT linux + linuxcnc setup so that would be another option
I wonder what it would take to get uc300+400 motion controllers mach4 plugin with spindle sync encoder input?
Admittedly... I need to finish off the mechanical conversion first of my lathe which is am going to try again at making a concerted effort to finish before motion controllers are required and decisions must be made....
