Help wiring THC
Re: Help wiring THC
Postby Spoolnms » Tue Nov 19, 2019 12:41 am
Im sorry but I do not see that as an option under the Post processors? Or am I missing something?
Spoolnms
Re: Help wiring THC
Postby Vmax549 » Tue Nov 19, 2019 2:05 am
Try updating your SheetCam version.
The post you are trying probably does not do arcs it converts everything over to lines.
(;-) TP
Vmax549
Re: Help wiring THC
Postby Spoolnms » Tue Nov 19, 2019 2:44 am
Using 6.0.30, no updates available :/
Edit: Ah found it, its on the development version. . .
Spoolnms
Re: Help wiring THC
Postby Spoolnms » Thu Nov 21, 2019 12:26 am
Well, used the UCCNC post, and itll reference twice, then go up like 8" then come down like 1" and start the cut, nowhere near the work piece :/.
--*** Set these values up to suit your machine ***
--this is the distance between each torch reference in MILLIMETRES
refDistance = 500
--Scriber X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--Use the special code 'nil' on the Z axis to disable it.
--In that case no Z values will be output at all while scribing.
--e.g scriberZ = nil
scriberX = 110
scriberY = 220
scriberZ = 0
--scriber axis. Leave this as nil if the scriber is fixed to the same axis as the torch
--scriberAxis = "A"
scriberAxis = "A"
--This an extra delay for the first pierce. The time is in seconds.
firstDelay=0
--*** End of settings ***
Spoolnms
Return to CNC Plasma
