Is it ok to use the 5v output on the UCBB1 board to power a UC300ETH?
Thank you,
Dennis
cncdrive wrote:The 5V output from on the UCBB is referenced to the same 0V as the 24V power supply input. This can be known because both return sides are marked 5V0.
So, if you will power the UC300ETH-5LPT with this 5Volts then you will use the same power supply for both the 5V and the 24V side which is a problem because you will bypass the isolation of the UCBB.
The 5Volts power is used to power the digital part, the UC300ETH side. The 24V is used to power the external side, the outputs abd inputs after the optical isolation. This side is where your relays, sensors and switches on your machine are connected. This two sides should be isolated from eachother, they should not share a common 0 Volts, so is why 2 separate powersupply should be used.
Users browsing this forum: Google [Bot] and 26 guests
