Hi Folks,
My AXBB controller is arriving today, I'm retrofitting a Romaxx WD-1 CNC (currently using Mach3). It appears the current control system uses the Mach3 Charge Pump driving a relay which seems to deliver or cut the drives' power. I've read elsewhere that pulling power to drives is a good way to damage the drives. If this is the case, it seems that I should perhaps use the AXBB's CHP output (to drive a relay) to enable/disable the drives, instead of completely pulling power from the drives. It also appears that the E-stop is in series with the Mach3 Charge Pump circuit which again drops power to the drives.
I'm interested to hear other, more experienced users' perspectives on this, and maybe even a suggestion or three?
Many thanks!
