AXCC_E
I followed the wiring picture 9.3.4 , believe I have all the correct settings in config but I get error that there is an external e-stop or limit switch pressed.
I dont understand the charge pump wiring, it is not wired into my switches because I dont have a reley
I put 24volts to port 1, 01 and this error goes away and the system works, but the green light for 24 volt goes out (3 lights grn,blue,grn) and the end stops no longer work
current setup:
I have 24 volts going to the contact switch and the switch return to port2 l1+ and the l2- going to ground like image 9.3.4 in the axbb manual.
so what is going wrong how does the port 1 01 get wired in?
The end of the manual illustration shows the charge pump wired in with a relay but it still goes to the 24volt source that feeds the switch. so again when I put 24v to the charge pump the e-stop error is gone, I can reset the system
and it runs via input commands but the end stops dont work. I have the 2 x end stops wired separate so I can square the gantry (not important) the opposit end of x with a stop , y stops both ends wired together, the z axis wired seperate
all of these work according to the diag page, lighting the Chiclets when depressed
is this a simple issue, or do I unwire each switch and work from the beginning adding one at a time, I will put this on hold to see if I can get informed befor I spark this thing. so many other projects I can work on
Thanks in advanced if there is a wizard that can understand my ramblings
jim
jim
