1.2112 screenset
Re: 1.2112 screenset
Postby NikolayUA24 » Tue Oct 08, 2019 7:38 am
cncdrive wrote:OK, then I know that deleting the texture with OpenGL is the problem. I just have to figure out why and how to further debug this. This particular code is not easy. Will have to think about it a bit...
You try to keep everything as it is. Video card: compatible with OpenGL 1.3
I have a controller of the Russian manufacturer, there are requirements. Video card: OpenGL 4.5
Such cards are expensive. And on laptops it works poorly, constantly losing communication.
I use Google Translator.
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 8:22 am
Yes, we keep the 1.3 OpenGL, will not use newer.
Can you please try the attached exe if the crashes?
Also if it not crashing then test if the slider is working ok?
UCCNC.zip
(1.57 MiB) Downloaded 559 times
Postby NikolayUA24 » Tue Oct 08, 2019 8:32 am
cncdrive wrote:Yes, we keep the 1.3 OpenGL, will not use newer.
Crashes
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 8:39 am
OK, and this one?
UCCNC.zip
(1.57 MiB) Downloaded 543 times
Postby NikolayUA24 » Tue Oct 08, 2019 8:50 am
cncdrive wrote:OK, and this one?
Crashes
NikolayUA24
Postby cncdrive » Tue Oct 08, 2019 9:17 am
Do you get a messagebox before the crash with this one?
If so plz make a printscreen.
UCCNC.zip
(1.64 MiB) Downloaded 515 times
Postby NikolayUA24 » Tue Oct 08, 2019 10:25 am
cncdrive wrote:Do you get a messagebox before the crash with this one?
I made a GIF animation.
Crashes
GIF animation.zip
(1 MiB) Downloaded 543 times
NikolayUA24
Postby ger21 » Tue Oct 08, 2019 11:11 am
Delco wrote:I have also experienced a problem where the spindle doesnt automatically turn off on a toolchange , I need to manually turn spindle on then off to make it go off - I assume its something to do with the HYwin14 plugin ?
You either need an M5 before the M6 (preferred method), or have the M6 macro stop your spindle. Dan's plugin has nothing to do with tool changes.
Postby cncdrive » Tue Oct 08, 2019 12:30 pm
Try this please for crash.
UCCNC.zip
(1.65 MiB) Downloaded 514 times
Postby cncdrive » Tue Oct 08, 2019 1:03 pm
Made a mistake in the previous exe, please test this one...
UCCNC.zip
(1.64 MiB) Downloaded 562 times
