1.2112 screenset
Re: 1.2112 screenset
Postby NikolayUA24 » Sun Oct 06, 2019 5:38 pm
cncdrive wrote:OK, checking through everything again, I see one more possibility.
Here is a new exe again, please check if it crashes or messagebox with text shown?
Problem Signature:
Problem Event Name: APPCRASH
Application Name: UCCNC.exe
Application Version: 1.0.0.0
Application Timestamp: 5d9a2441
Error module name: StackHash_2f93
Error version of the module: 6.1.7601.24520
Error Timestamp: 5d673de3
Exception Code: c0000374
Exception Offset: 00000000000bf302
OS Version: 6.1.7601.2.1.0.256.1
Language Code: 1049
Additional Information 1: 2f93
Additional information 2: 2f933b4816d25c272a6159af2739b258
Additional Information 3: 8e38
Additional Information 4: 8e38bdbbd90d9e055d9122e3140e06cb
I use Google Translator.
NikolayUA24
Postby cncdrive » Sun Oct 06, 2019 5:41 pm
OK, new file with 6 messagebox texts. Please tell me if you see any of them and after which one does it crash?
UCCNC.zip
(1.63 MiB) Downloaded 447 times
Postby markcadcam » Sun Oct 06, 2019 5:46 pm
I get message Boxes 1 thru 4, then when I click on message box 4 it crashes.
markcadcam
Postby NikolayUA24 » Sun Oct 06, 2019 5:46 pm
cncdrive wrote:OK, new file with 6 messagebox texts. Please tell me if you see any of them and after which one does it crash?
Problem Signature:
App Timestamp: 5d9a26da
Language Code: 1049
NikolayUA24
Postby cncdrive » Sun Oct 06, 2019 5:51 pm
Thanks.
It is even more strange now.
Between point 4. and 5. there is only these 2 lines of codes:
starthiderpanel.Visible = false; // The screen is ready to show, so hide the hider panel
starthiderpanel.Refresh();
It just removes an empty grey panel from the screen, nothing else.
Anyways, what I did now is that I removed these 2 lines and kept the numbered messagboxes in place.
And made that panel unvisible by default.
I'm really curious to see what happens now. New exe attached.
UCCNC.zip
(1.56 MiB) Downloaded 484 times
Postby markcadcam » Sun Oct 06, 2019 5:57 pm
I get message boxes 1 thru 3 and the screen shot until I click message box 3, then it crashes.
markcadcam
Postby NikolayUA24 » Sun Oct 06, 2019 5:59 pm
cncdrive wrote:Thanks.
Problem Signature:
Application Timestamp: 5d9a28e5
Language Code: 1049
Got a message from another forum.
win 10 (64bit) - the program loads well, the interface works!
Probably easier to switch to win 10 (64bit)
NikolayUA24
Postby cncdrive » Sun Oct 06, 2019 6:00 pm
Can you please check if the Plugininterface.dll is in the UCCNC folder? I mean is it not missing, right?
Postby markcadcam » Sun Oct 06, 2019 6:04 pm
You had me delete all the dll files in the plugin folder. I don't have it.
markcadcam
Postby cncdrive » Sun Oct 06, 2019 6:05 pm
Not in the plugins folder, but in the UCCNC folder. In the top level folder of the UCCNC in other words.
Users browsing this forum: Google [Bot] and 1 guest
