Hi.
Ok, I am in front of the CNC Now, I have tested a number of things with the meter.
Tested both 24v & 5V Power supplies, they are outputting the correct voltages and are grounded well.
However, when testing the voltage between 5V0 & AO1 - the highest I have seen is 0.07.. It does fluctuate when moving the SRO slider, but barely, So I am assuming that is the issue here?
Settings in UCCNC - I/O SETUP - Spindle PWM -> analog ch. : 1
