Using Mach3 with UC300eth
Postby Vmax549 » Sat Sep 21, 2019 1:44 am
Using teh UC300eth with mach3 and the UCCNC plugin DOES the THC function work ?? Or was it not included in teh plugin?
(;-) TP
Vmax549
Re: Using Mach3 with UC300eth
Postby cncdrive » Sat Sep 21, 2019 2:19 am
Yes.
Postby stirling » Thu Sep 26, 2019 8:39 am
How do you turn THC on?
I've tried doOEMButton with OEM code 123, startTHC and even THCon (which I know doesn't work even with the parallel port)
UC300ETH_5LPT
Razordance DTHC
http://www.razordance.co.uk/THC.htm
stirling
Postby cncdrive » Thu Sep 26, 2019 9:46 am
With the THC button on the screen?! :)
But we have always used the UCCNC and it has an M code to turn the THC on/off.
You will have to ask machsupport about how to do that in mach3.
Postby stirling » Thu Sep 26, 2019 10:34 am
I hoped it was clear I know how to turn THC on in Mach3. I also hoped it was clear that none of the methods I stated work when using the plugin for the UC300ETH.
I got the plugin from your site so I was hoping you may have some insight into why none of the available methods in Mach3 appear to work.
UC300ETH_5LPT
Razordance DTHC
stirling
Postby cncdrive » Thu Sep 26, 2019 12:07 pm
I don't know sorry. It works at us with the THC button.
Postby stirling » Thu Sep 26, 2019 1:07 pm
Which screenset are you using?
UC300ETH_5LPT
Razordance DTHC
stirling
Postby cncdrive » Thu Sep 26, 2019 2:46 pm
The default plasma screen.
Postby stirling » Fri Sep 27, 2019 7:51 am
progress - wiped Mach3 - clean install and of plugin. Now working.
UC300ETH_5LPT
Razordance DTHC
stirling
Postby NikolayUA24 » Mon Sep 30, 2019 5:18 pm
The controller works with version 2.63
I use Google Translator.
NikolayUA24
Return to Mach3/4 Discussions
