Z axis not stopping
Z axis not stopping
Postby cas_shs » Sun Aug 25, 2019 10:51 pm
When i press the zero all button my Z axis goes straight up through the homing switch and i have to press reset to stop the motor. Any idea what can be causing this. The machine homes fine but I cant press goto zero or any park position because the z axis never stops. Thanks for any help.
cas_shs
Re: Z axis not stopping
Postby cncdrive » Sun Aug 25, 2019 10:57 pm
Never say "never". You just assuming that it would never stop, but is not likely to happen. You can't not know, because you have no infinate time to verify that it "never" stops. :)
The goto zero sends the Z axis to the SafeZ height first if the actual Z height is lower then the setup Z height.
Your set Zheight is probably higher than it should be. Check that setting...
Postby cas_shs » Mon Aug 26, 2019 12:39 am
Should the safe z height be in inches or millimeters? It is set at 25 but i don't know if that is inches or millimeter i changed it to 4 but it did the same thing.
cas_shs
Postby ger21 » Mon Aug 26, 2019 1:39 am
It should be in whatever units everything else is in. Did you set your steps/unit to steps/mm, or steps/inch?
Note that Safe Z is in Work Coordinates, and would be relative to your Z zero position.
Postby cas_shs » Mon Aug 26, 2019 2:17 am
Ok I will check that tomorrow. I think I am gonna buy your 2017 screenset tomorrow. I understand the screens better
cas_shs
