MACH3 configuration Import
Postby daydreamn1134 » Thu Aug 08, 2019 9:50 pm
Can I import a configuration file from Mach3 to use the configuration in UCCNC?
Any help is greatly appreciated! :)
daydreamn1134
Re: MACH3 configuration Import
Postby thegreatwaldo » Fri Aug 09, 2019 9:59 am
thegreatwaldo
Postby ger21 » Fri Aug 09, 2019 10:42 am
While it can import Mach3 .xml files, you may still need to do some configuration yourself, as they are two different programs, with different settings. Some things will import, others may not.
Postby daydreamn1134 » Tue Aug 13, 2019 6:39 am
Thank you so much! I will give it a go...
daydreamn1134
Users browsing this forum: Bing [Bot] and 16 guests
