BOB Recommendation
BOB Recommendation
Postby CL_MotoTech » Fri Aug 09, 2019 1:42 pm
I am using a UC300eth-5lpt with a MX3660 and a Gecko G540. I only have two inputs and three outputs left. As a result, I'd like to add an additional BOB. I don't foresee needing a ton more outputs/inputs, but having the room to grow is appealing.
I checked out a few different websites and I am struggled to come to a conclusion.
So if anybody has any suggestions I would greatly appreciate it.
CL_MotoTech
Re: BOB Recommendation
Postby ger21 » Fri Aug 09, 2019 2:16 pm
If you are already using both "standard" ports on the 5LPT, then a CNC4PC C10 is probably what you want. I'm not aware of any other bi-directional breakout boards.
Postby CL_MotoTech » Fri Aug 09, 2019 4:39 pm
I am using ports 2 and 3 on the 5lpt, so that leaves the bi direction ports open. The price is right on the C10, so I think I'll order it up.
Thanks, gents.
CL_MotoTech
Postby Robertspark » Fri Aug 09, 2019 4:41 pm
note they are not bidirectional ports...
all ports are fixed
some are standard Ltp ports and some are ecp ports (with inputs on pins 2to9
Postby CL_MotoTech » Fri Aug 09, 2019 5:24 pm
Yeah, I checked out the documentation.
Looks like it will do what I need.
CL_MotoTech
Users browsing this forum: No registered users and 22 guests
