Yesterday morning I upgraded my software from 1.2046 to 1.2110. Now my Estop will only activate when the switch is closed, even if I change the setting 'Active low'. The setting 'Active low' makes no difference checked or unchecked. I moved the Estop to another pin and it does the same thing. I also moved the Estop to another breakout and got the same result. Was there a change made in version 1.2110 for the Estop to activate only when a switch is closed?
I'm using a UC300 (USB) controller with a 5LPT board and 2 CR10 breakout boards. The Diagnostics shows everything is working properly. The Diagnostics shows the change checking 'Active low' but the Estop triggers only when the switch is closed. This appears to be a bug.
Mark
